At this point you’d be totally within your rights to ask how Celonis is different from the infinite sea of technologies promising to “agentify” this and “reinvent” that. So let’s break down the Celonis Platform step by step, and let you decide who offers the leading enterprise agentic ai. No frills, no hype.
The Celonis Platform works in three stages:
1. Analyze
This is the stage that unlocks full visibility into how work is truly running across your enterprise. Securely extracting data from your various source systems (think Salesforce, Workday, ServiceNow, or industry-specific systems like FIS, CTMS, MES and beyond), the Celonis Platform creates a dynamic digital twin of your operations that updates in real time. Using this digital twin, the platform then surfaces root causes, and sizes the value of fixing each gap, so you know exactly which problems are worth solving, and in which order.
2. Design
This is the stage where you start redesigning your processes long before committing to a build. You can draft a best-practice target model, simulate each change against real cases, and plan transformation in waves. Basically, by giving agents a way to reason, predict, run what-if scenarios, evaluate pros and cons, and make tailored recommendations, you learn what works on paper and in practice, before committing any budget.
3. Operate
This step is where the action is. You put each new process into production and track it in granular detail. Your teams can build the apps and agents that run each process either on or off-platform, with the ability to model adherence to the target model, and closely measure value realized over time.
The best part? The Celonis Platform runs as a closed loop, meaning every change and deviation flows back into the model. So when an agent takes an unexpected path or a team navigates a new step in a different way, that activity informs the next phase of analysis and design, and so on.
The Celonis Context Model sits at the heart of all of this, giving both your people and AI agents a continuously updated picture of how the business operates — and should operate.
