Is it even possible to modernize without migrating?
In short, yes. Migration is only one part of the enterprise modernization arsenal.
Companies that choose not to do a system migration usually pursue other types of modernization in order to remain competitive. Organizations can (and should!) also pursue projects like application optimization, process optimization, AI implementation, and automation. The best modernization strategy is one that is ongoing — not dependent on a one-and-done project.
These other modernization projects can be much cheaper, easier, and less risky than a migration. Any initiative that helps technologies work better, helps them work better together, and helps an organization incorporate any useful new advances or tools could be considered a part of enterprise modernization. System migration can and often does fall into this category, but certainly it isn’t the sum of it.
What’s standing in the way of modernizing systems, whether companies migrate or not?
Many companies have trouble modernizing their systems not because the systems are too old or too unwieldy, but instead because they’re too opaque.
For IT, core systems are too often “black boxes” which no one really knows how to safely customize, fix, or retrofit. And outside of IT, it’s worse: most businesses have no shared understanding of how processes flow across systems, or how people interact with them.
This makes modernization projects of all sorts, from migration to AI implementation, hard to pull off on time, within budget, and without problems.
Put simply, IT and the rest of the business need to have a shared, objective, and real-time, understanding of what’s actually going on with their systems, and be able to collectively answer questions like:
- Who’s using them?
- For what processes?
- For what purposes?
- When?
- How do these processes impact or depend on any other systems, applications, or teams?
If IT and the business don’t have a way to consistently answer these questions, modernization projects become much more difficult.
How can Celonis Process Intelligence help companies that decide not to pursue a system migration?
Processes are the only things that run across systems and technologies. Because of this, they generate extremely useful data for companies trying to understand how their systems and technologies are actually used, like in those questions just above.
Following a process end-to-end can show where systems and technologies are working well, and where they can be improved. If a company wants to modernize without migrating, this is crucial information. All of those modernization projects mentioned earlier become much more effective when they’re built on an objective, real-time picture of how things really run. That’s exactly what Celonis does.
Beyond visibility, the Celonis Process Intelligence Platform also lets companies take action to make targeted improvements across their processes. Older system that’s clunky to work in? Use Celonis to trigger actions within it, without having to go into the system itself. Instead of replacing your technologies, Celonis makes them smarter, letting you orchestrate the right actions at the right times, and generating meaningful predictions, recommendations, and solutions.
And if AI is part of your modernization scheme (it really should be), Celonis helps with that, too. Process Intelligence gives AI the unique process context it needs to deliver ROI for your unique enterprise, consistently and at scale.
Make what you have work better than ever
With Celonis, you can optimize your systems and processes on your own terms and timeline – no migration necessary.
Want more in-depth modernization intel, whether you’re migrating or not?
- Read Modernize without migrating, our newest e-book that covers all the ways you can modernize your enterprise without undergoing a system migration.
